Date/Time: Wed, 05 Feb 2025 06:43:06 +0000
selective global cross hair
View Count: 756
[2020-03-03 18:00:59] |
User540504 - Posts: 15 |
Good afternoon, I have 1 big chart and 3 smaller ones on the same screen. I have the global cross hair enabled but it doesn't help when looking at the daily chart (it just covers the candle). Is there a way to selectively unlink a single chart? Thanks, Gabriel |
[2020-03-04 19:08:54] |
If you disable Global Settings >> Tool Settings >> Use Common Drawing Tool for Charts, then you can disable the Chart Values tool on any chart you do not want the global chart values tool to work on.
