Date/Time: Wed, 05 Feb 2025 06:50:23 +0000
TPO : Define the time of the initial balance
View Count: 1308
[2020-03-03 14:24:49]
User210127 - Posts: 23
Hi there. How can you:can you have a 24 hours TPO profile but define a precise start time and not at the start of the 24 hours profile (whenever that is) ? For example the TPO may start at 23:00:000 and end at 21:59:59 but the IB will only start at 07:00am GMT.
Many thanks
[2020-03-04 07:21:20]
Any idea? Thought it would be basic simple stuff, but perhaps not feasible?
[2020-03-04 19:07:35]
In the case of a TPO profile chart the initial balance time start time is going to based upon the session times of the chart. If you want to have it different than those session times:
You cannot do this with the TPO Study. What you can do is have one chart with the TPO study on it as it is now, then use another chart and have the Initial Balance study on it with the Start and End time as you desire. Refer to the information here:
Initial Balance
