Date/Time: Wed, 05 Feb 2025 06:39:24 +0000
reverse footprint lines aren't correct
View Count: 597
[2020-03-03 13:55:47]
User389151 - Posts: 37
anyone know about this issue, in footprint chart(reverse footprint), the ema and vwap lines that i put on is a little off? when i change footprint chart to range, it's fine. because i want to use reverse footprint, how to make the lines to be exactly correct? See attached. Thanks
imagerange footprint.JPG / V - Attached On 2020-03-03 13:54:46 UTC - Size: 165.9 KB - 255 views
imagereverse footprint.JPG / V - Attached On 2020-03-03 13:54:53 UTC - Size: 184.66 KB - 260 views
[2020-03-03 18:10:23]
Make sure the Scale Range of those studies is set to Automatic:
Chart Scale and Scale Adjusting: Opening the Scale Settings Window For a Study
[2020-03-03 20:58:25]
tried it, didn't work. any other suggestion?
[2020-03-04 18:26:40]
Provide that chart by following these instructions here:
