Date/Time: Thu, 06 Feb 2025 07:08:18 +0000
5 year Treasury scale
View Count: 829
[2020-03-03 13:42:27] |
phlapjack - Posts: 7 |
Not sure what I am missing in setting up this chart as to why the sierra chart DOM is not displaying all the price levels. I have tried scale at 1/128, and scale set by data
screen shot1.jpg / V - Attached On 2020-03-03 13:39:55 UTC - Size: 387.57 KB - 317 views Attachment Deleted. |
[2020-03-03 17:45:54] |
You need to update to the latest version of Sierra Chart for proper support for bond price formatting. Instructions: Software Download: Fast Update There is a technical notice about this when you start Sierra Chart. After the update, follow the instructions here to apply the updated settings to those bond symbol charts: Global Symbol Settings: Update/Apply Symbol Settings to Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-03 17:46:02
[2020-04-21 19:04:59] |
User104854 - Posts: 457 |
Is there a way to get this to work on previous versions? I'm having issues with some of the later versions. Currently using 2041. I've tried to use decimals (1/128 = 0.0078125) but the DOM is still not displaying all of the price levels.
[2020-04-21 19:25:04] |
No there is not. The only solution is updating.
