Date/Time: Wed, 05 Feb 2025 06:57:32 +0000
FXCM: moving attached orders around
View Count: 567
[2020-03-03 10:34:40]
ycomp - Posts: 321
Hello, I would just like to confirm that this means that if you have attached orders and move them around on the chart, then these new trigger prices will be updated on the (Sierra) server... and then ultimately in the FXCM server.
also, do LMAX attached orders also behave the same way (multiple orders when using attached orders) or will they be stoploss and take profits of the position that is open on the LMAX server?
When using Attached Orders in Sierra Chart, whether they are managed on the client-side or the server-side, both the Target order and Stop order are distinct orders which are managed by Sierra Chart either on the client-side or the server-side. These are not FXCM managed orders. The parent order, the Target order and the Stop order are three separate orders. That is how they will appear in FXCM Trading Station. Sierra Chart does not use any child order functionality on the FXCM side for Target or Stop orders since it is incompatible and for various other reasons.
https://www.sierrachart.com/index.php?page=doc/FXCMTrading.php#FXCMTradingStation
Date Time Of Last Edit: 2020-03-03 10:45:24
