Date/Time: Wed, 05 Feb 2025 07:01:38 +0000
Match shared .cht with personal configuration.
View Count: 539
[2020-03-03 00:43:36]
User556932 - Posts: 31
Question:
Is it possible to match the settings of a shared .cht with my local settings?
Background:
Another SC user has shared several . cht with me.
When I open them, the appearance is very different to mine eg candles and text very large. Note this is not related to the general screen size you can change using the arrow keys. I think the other user must have applied a different resolution. BTW. they do not know if they have changed.
[2020-03-04 10:55:14]
Yes, you can easily do this. Just go to Chart >> Graphics Settings - Chart and select the option at the top of that window for Use Global Graphics Settings Instead of These Settings. Select the OK button and everything should change to your global defaults.
Refer to the information here:
Graphics Settings: Use Global Graphics Settings Instead of These Settings
