Date/Time: Wed, 05 Feb 2025 06:54:28 +0000
Platform Freezing on Startup
View Count: 873
[2020-03-02 19:12:58]
User215357 - Posts: 2
For the past week or 10 days, my SC platform is freezing on startup. At first I assumed it was possibly the extra load on the data feeds worldwide caused by all the volatility. But it continues even now and other SC users I have talked with are NOT experiencing any similar problems. I am running the Denali setup and on startup am loading only 1 Chartbook, comprised of 3 charts (CLx2 + ES) running the same studies I was using before the problem started.
This is now the sequence of events on EVERY startup:
- The Connection Status Light is RED - NOT CONNECTED and remains this way FOR sometimes 5 MINUTES or more before turning Green/Live;
- The 3 Charts are showing Historical Download in Progress, and they stay that way until the Connection Status changes to Green/Live;
- Even after all 3 charts are active and the status light Green, the entire platform is very sluggish and non responsive. For example, if I attempt to change anything on any of the charts, the response is very slow and jerky.
- Sometimes, but not often, a PC or Platform restart helps.
As a result, the platform is completely useless for trading and evaluating studies. IT NEEDS HELP AND SO DO I....
[2020-03-02 22:30:21]
Run Sierra Chart in Safe Mode:
Sierra Chart - Software Login Instructions: Using Safe Mode
And also refer to this help topic:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
On that page first refer to:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.16 - What to do if Sierra Chart is in a frozen state for an extended time due to extended high CPU usage caused by an automatically or manually opened Chartbook
