Date/Time: Wed, 05 Feb 2025 06:50:09 +0000
BUG Report: Sim account setting in Chart Trader not saved when leaving Sim mode
View Count: 546
[2020-03-02 17:23:37]
ycomp - Posts: 321
if you select a sim account that is not Sim1 (e.g. Sim2) in simulation mode and then disable simulation mode, if you then re-enable sim mode then the account in chart trader selected will always be Sim1...
would be nice to have it as the previously used one (Sim2) as it is easy to forget the sim account needs to be selected again after you re-enable sim mode..
[2020-03-02 23:00:35]
This will be supported in the next release.
