Date/Time: Thu, 24 Sep 2026 21:30:40 +0000
DTS Issue Data
View Count: 1024
[2020-03-02 15:35:19]
Keezilla - Posts: 5
I need an example code for using the dtc server via java client either websocket or tcp session to recieve market data from the platform
essentially all im trying to do is extract data from you guys using c# or java.
Also can you tell me where you pull your index prices for us30 etc from ? is it fxcm? and fixapi? also is there any other direct feeds for us30 ws30 de30 dax dow etc for indexs or something that corresponds directly from the exchanges we just need to be top of the book and get as many prices as possible for arbitrage feeds
[2020-03-02 21:28:13]
If you are using Java we would not bother with a websocket and just use a standard TCP/IP connection and use JSON encoding. This is very easy. Refer to:
Data and Trading Communications (DTC) Protocol Server
CFDs like US30, are from FXCM.
We do offer the Sierra Chart Exchange Data Feed with cash and futures indices from the actual true sources:
Date Time Of Last Edit: 2020-03-02 21:28:26
[2020-03-03 17:02:53]
Keezilla - Posts: 5
Yes i Need the true sources for wall street 30 (US30) Nasdaq 100 index (NAS100) and DAX. Also where is your server located? We need true source plus fastest data. Thanks tell me what to subscribe and symbol name
[2020-03-03 17:04:18]
Keezilla - Posts: 5
And also for premiums how do I subscribe is this what you were referring to also? and we need as much pricing / quotes per second received , thanks
[2020-03-07 02:31:46]
We apologize for the response.
The Sierra Chart Exchange Data Feed does provide data for these:
But not the cash DAX index. That is not available.
The servers are in US Chicago.
In regards to stock index futures premiums, refer to:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#StockIndexPremiums
Date Time Of Last Edit: 2020-03-07 02:32:04
