Date/Time: Wed, 05 Feb 2025 06:57:33 +0000
Problem with recent ask/bid volume of DOM
View Count: 587
[2020-03-02 15:33:11] |
User165114 - Posts: 18 |
I have attached 2 screenshots of my DOM. Recent ask/bid volume is not horizontally aligned with the price of my DOM. Is there a way to make the recent ask/bid volume to be on the same level as its corresponding price? Note: this problem is not observed when I replay my chart Date Time Of Last Edit: 2020-03-02 15:42:57
[2020-03-02 20:03:24] |
The issue relates to bond symbols. We first want you to follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings And uncheck Global Settings >> Symbol Settings >> Use Custom Symbol Settings Values. After that we want you to restart Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-02 20:03:51
[2020-03-03 13:23:58] |
Problem solved. Thank you.
