Date/Time: Wed, 05 Feb 2025 09:55:47 +0000
[Programming Help] - ALERT HELP: buy / sell arrows with accompanying email + audible alert
View Count: 1485
[2020-03-01 07:07:06]
User80732 - Posts: 26
Hi Team :)
BUY ALERT:
Can you please help me understand how I can have a green buy arrow form below the signal candle with an accompanying email + audible alert WHEN:
-light blue ma is above yellow ma
-yellow ma is above red ma
-red ma is above dark blue dashed ma
AND
the first green candle prints AFTER a minimum of 3 or more CONSECUTIVE red renko-ashi bars print- so long as they (the consecutive red bars) each close at or above the red MA.
note: The first green candle IS the signal candle
(See Example for visual: https://prnt.sc/r9r842)
SELL ALERT:
How to have a red sell arrow form above the signal candle with an accompanying email + audible alert WHEN:
-light blue ma is below yellow ma
-yellow ma is below red ma
-red ma is below dark blue dashed ma
AND
the first red candle prints AFTER a minimum of 3 or more CONSECUTIVE green renko-ashi bars print- so long as they (the consecutive green bars) each close at or below the red MA
note: The first red candle IS the signal candle
(See Example: https://prnt.sc/r9r8is)
Also attached is the study used in the above screenshots for reference if that helps.
Thank you so much in advance! :)
Date Time Of Last Edit: 2020-03-01 07:08:07
attachmentRA WAVE ALERT.StdyCollct - Attached On 2020-03-01 07:03:07 UTC - Size: 121.01 KB - 382 views
[2020-03-01 09:39:14]
Ackin - Posts: 1865
I can do the study for you, I just don't understand this: "so long as they (the consecutive red bars) each close at or above the red MA."
[2020-03-01 21:11:00]
RE: I can do the study for you, I just don't understand this: "so long as they (the consecutive red bars) each close at or above the red MA."
For a Buy Setup: If one of the corrective red bars closes below the red MA then the setup is invalid. Does that help clarify??
For example here are some visuals with annotations:
Valid Setup: https://prnt.sc/r9xuwi
Invalid Setup: https://prnt.sc/r9xtcy
Example of valid and invalid setups:
https://prnt.sc/r9zzt6
https://prnt.sc/ra02h3
Perhaps the conditions for the setup could be outlined more simply:
1- MAs all need to be in proper order
2- Minimum 3 consecutive candle correction
3- None of the corrective candles can have a close above red MA (when selling) or below red MA (when buying)
4- Entry signal is the first green/red bar after correction.
I hope that helps. Thank you in advance!
[2020-03-01 23:01:28]
Ackin - Posts: 1865
It looks interesting. We have similar studies but in a different view. The points of entry for trade will very often coincide. Nice ...
ok,I'll create it (tomorrow)
[2020-03-03 17:43:46]
Any luck on the alert/signal by chance Ackin? :)
[2020-03-03 17:45:43]
Ackin - Posts: 1865
It's done... just testing it ... I'll write after complete finish test...
[2020-03-05 18:13:40]
Hi Ackin,
At the risk of bugging (definitely not trying to bug) But very excited to know if you've had any luck compiling that alert formula??
[2020-03-05 19:11:56]
Ackin - Posts: 1865
Hi, No formula. You have everything in one ACSIL study. It has more use for trading auto system than formula. It's done ... I added other optional conditions in the study settings, such as the length of the previous movement ....I'll be in the office in about +- three hours. Then you can download it for free from our forum. I will update there.....
contact link:
[2020-03-05 19:46:57]
Hi Ackin,
Wow. Very cool. This is all new territory for me so it'll be fun/exciting to be a part of your forum. I just registered and I guess will wait for further instructions from an email from you on getting logged into the forum. Thank you!
[2020-03-05 19:56:00]
Ackin - Posts: 1865
OK, if the registration email does not arrive within 20 minutes, write me an email. I haven't got anything from you yet.
zyp.sierra@gmail.com
[2020-03-05 20:19:44]
Email Sent :)
[2020-03-06 09:40:05]
Ackin - Posts: 1865
I added some improvements. Through open markets I will test and fine-tune the details and in the evening you will have a new update.
It's a nice tool. Thank you for your idea ...
