Date/Time: Mon, 25 Nov 2024 03:25:21 +0000
[User Discussion] - disable auto trading not working
View Count: 2064
[2014-01-08 03:12:51] |
toews&kane - Posts: 209 |
As you can see here, in the attachment entry time was at 8:44:55 in simulation mode in $J$28 the code is as follows: =AND(J8=0,OR(J41-INT(J41)<TIMEVALUE("08:45:00"),J41-INT(J41)>TIMEVALUE("14:31:00"))) starting with 0 postion my entry time cannot be 8:44:55 can somebody please tell me why this is happening? |
[2014-01-08 04:16:31] |
Sawtooth - Posts: 4120 |
There is no attachment. Please reattach.
[2014-01-09 02:05:45] |
it's just the trade entry in the activity log
[2014-01-09 05:22:30] |
If J28 is TRUE, there will be no entry and no exit. Things to consider: - Your SC timezone is not the same as your local timezone, and the 08:44:55 is actually the local time, not the chart time (J41) - Can you repeat the spurious entry in Replay Chart? - The entry was manual and not from the autotrading spreadsheet. - The entry was from another chart of the same symbol. - If you are scaling in, see this: http://www.sawtoothtrade.com/example-4.html Date Time Of Last Edit: 2015-08-14 01:50:59
[2014-01-09 05:34:29] |
- Can you repeat the spurious entry in Replay Chart? - no - The entry was from another chart of the same symbol. - no there's something odd happening for sure |
