Date/Time: Thu, 06 Feb 2025 14:13:54 +0000
Backtesting - Jumping from trade to trade
View Count: 767
[2020-02-29 14:54:45]
User841604 - Posts: 20
Dear Sierra,
Is there a way to jump from trade to trade 'on a chart', once a backtesting has finished (It's energy consuming to go manually from trade to trade to see visually what happened).
I usually have to go back 200 trades. If there is no way already implemented. Is this easy to program ?
All the best
[2020-02-29 18:16:13]
Mauro - Posts: 45
I add myself to this request. It would be really handy to have a goto -> next trade and a goto -> previous trade. Even fancier would be to have the chart synchronized with the trading log, so when I select the trade on the log the chart move to the right date-time.
Mauro
[2020-02-29 19:37:42]
User61576 - Posts: 445
+1
[2020-03-04 03:37:13]
Sierra_Chart Engineering - Posts: 18313
We will add menu commands to support this into the next release. It should not be difficult to implement.
[2020-03-04 07:09:34]
Ackin - Posts: 1865
Is it possible to create a control command also into ACSIL? Thanks
[2020-04-29 17:50:25]
Mauro - Posts: 45
I see the menu commands, but how do they work? When I click on them to check my trades nothing happens. Are they active?
Thank you
Date Time Of Last Edit: 2020-04-29 17:50:50
[2020-04-29 20:17:47]
TedMar - Posts: 190
+1
[2020-04-30 11:38:46]
You need to make sure the order fills are displayed on the chart:
Chart Trading and the Chart DOM: Displaying Order Fills on the Chart
[2020-04-30 18:04:27]
Mauro - Posts: 45
Got it - I could see my entries and exits on the chart but all the Display checkboxes in the Chart Trading Settings were off. I turned on Display Node and now it works.
Thank you
