Date/Time: Wed, 05 Feb 2025 04:02:23 +0000
[Programming Help] - I have a custom study and I cannot load it up into sierra charts
View Count: 999
[2020-02-28 20:20:17]
User730002 - Posts: 9
it is in C:SierraChartACS_Source\
the file name is Top_UltimateBreakout.dll.cpp file size 1016B
I am trying to load it into sierra charts its in there under custom studies but I cannot open.
attachmentTOP_Ultimate_Breakout.dll - Attached On 2020-02-28 19:54:37 UTC - Size: 789.5 KB - 411 views
[2020-02-28 20:38:58]
Ackin - Posts: 1865
Why "C:SierraChartACS_Source\" ?
Move file Top_UltimateBreakout.dll to folder "data" and try it again
[2020-02-28 21:03:49]
its in sierra data file then what do I do
[2020-02-28 21:12:16]
Ackin - Posts: 1865
1) Sierrachart Turn off
2) Move dll file into "Data" folder in Sierra Chart (default C:\SierraChart\Data\)
3) Run Sierrachart
4) Add custom study
In Menu / Analysis / Studies Click on "Add Custom Study" where you'll find this new library.
[2020-02-28 21:17:27]
Ackin - Posts: 1865
Custom Study Problems - Things to Check
Resolving Custom Study File and Access Issues: Custom Study Problems - Things to Check
For instructions, refer to How to Build an Advanced Custom Study from Source Code (.CPP file):
[2020-02-28 21:19:44]
I only have analysis then the studies is unable to click on
[2020-02-28 21:21:08]
I tried with that stuff still cant get it to work
[2020-02-28 21:26:17]
its nowhere in the new library
[2020-02-28 21:37:39]
Ackin - Posts: 1865
It is important to have the latest update if the dll file is newer (it might not be in the library list afterwards)...
also check this:
Sierra Chart - Software Login Instructions: Using Safe Mode
1) If Sierra Chart is running in Safe Mode, custom studies cannot be used. For more information and to disable Safe Mode, refer to Safe Mode.
5) To use an Advanced Custom Study, in Sierra Chart select Analysis >> Studies on the menu.
6) Press the Add Custom Study button. Refer to the image below.
How to Use an Advanced Custom Study or a Study Collection: How to Use an Advanced Custom Study Provided To You
Date Time Of Last Edit: 2020-02-28 21:50:27
[2020-02-28 21:39:59]
forget it this is crazy I should be able to drag and drop with all this technology
[2020-02-28 22:00:58]
Its not in safe mode
[2020-02-28 22:06:23]
Ackin - Posts: 1865
The last issue possible to think of is different 32-bit and 64-bit version (library dll vs Sierrachart)
How to Use an Advanced Custom Study or a Study Collection: Custom Study Not Listed or Not Displaying on Chart
Difference Between 32 and 64-bit Versions
Software Download: Difference Between 32 and 64-bit Versions
Date Time Of Last Edit: 2020-02-28 22:09:32
[2020-02-28 22:25:53]
no doesn't work
