Date/Time: Wed, 05 Feb 2025 03:56:04 +0000
BID VOLUME ASK VOLUME DIFERENCE PER TICK IS NOT WORKING
View Count: 886
[2020-02-28 10:09:47] |
User719206 - Posts: 93 |
Hello , i use the bid and ask volume difference per tick , in the number calculated value, in connexion with bitmex , and it looks display random valu , what about this study ? Thanks for your help Date Time Of Last Edit: 2020-02-28 10:24:36
XBTUSD-BMEX[M] 15 Min #1 2020-02-28 10_03_10.882.png / V - Attached On 2020-02-28 10:03:44 UTC - Size: 19.22 KB - 312 views |
[2020-02-28 10:23:24] |
not really random to be honest but incorrect , to give an exemple in a 15 min bar the price move to from 9778 to 9786 ( 8 x 2 we have 16 tick ) the bid and ask difference displayed is -4 407 133 the resulte should be - 275 445 but its - 68 861 .
Date Time Of Last Edit: 2020-02-28 10:24:59
[2020-02-28 18:12:53] |
To begin with, your image shows values of 9778 and 8786 a difference of 992, not 16. Additionally, you need to measure from Low to High, not from Open to Close. Refer to the information here for that subgraph: Numbers Bars: Numbers Bars Calculated Values 2 Subgraph Descriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
