Date/Time: Wed, 05 Feb 2025 04:05:49 +0000
[User Discussion] - Can't connect to my CQG WebAPI data feed
View Count: 724
[2020-02-28 03:13:14] |
User829272 - Posts: 1 |
I'm getting an error message saying I can't connect to the live data feed due to an incorrect username and or password...Reentering the correct username and password doesn't work...not sure how to proceed
[2020-03-02 00:35:48] |
Sierra_Chart Engineering - Posts: 18262 |
You need to ask your Broker for help with this. This is not something we can help with. Instead of using CQG, we recommend using this service instead: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-02 00:36:20
