Date/Time: Wed, 05 Feb 2025 03:52:32 +0000
continous chart
View Count: 530
[2020-02-27 22:22:43] |
User749229 - Posts: 7 |
hello i am trying to put a continuous chart together for E mini sp500 index and i would like to load at least 10 years but for some reason i can t .can someone give some pointers please .thanks
[2020-03-02 00:23:30] |
Sierra_Chart Engineering - Posts: 18262 |
If you want a continuous Intraday chart you are going to need to use the Denali Exchange Data Feed: Denali Exchange Data Feed Another important thing is to update to the current version of Sierra Chart: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-02 00:24:09
