Date/Time: Mon, 10 Mar 2025 07:05:05 +0000
Chart keeps losing
View Count: 720
[2020-02-27 17:34:08] |
marwhitt - Posts: 29 |
Even though using updated version (2057 as of today), chart keeps losing connection. Usually have to close chart and reopen. Sometimes when closing chart, "Saved Chartbook" window opens, which I then close. This has been going on for quite some time. A fix or suggestions would be appreciated. I have 100 mbps cable internet Using TransAct Futures Windows 10, 64 bit |
[2020-02-27 19:05:37] |
You are using an externally provided data feed that is not from Sierra Chart and that is where the problem is. The recommended solution is as follows: Update Sierra Chart to the latest version following these instructions: Software Download: Fast Update Enable Global Settings >> Data/Trade Service Settings >> Service Setting >> Disable Market Data Connection. Follow the instructions to activate and pay for the Denali Exchange Data Feed including the relevant exchanges: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* You will not have the described problem with the Denali Exchange Data Feed. ---- Now we have heard from Transact about the issue and they have given us some things to work on which will reduce bandwidth for the feed which they say will help. So those are going to be released over the next week. We will have one release out, we think today or tomorrow with one improvement. But still the Denali data feed is going to deliver the very best consistent performance. And be trouble-free. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-27 19:06:20
[2022-03-18 13:35:01] |
I am still waiting on my Cannon Trading account to be completed. In the meantime, my charts (v 2348) will not connect again today. Suggestions appreciated. Software version: 2348 64-bit | 2022-03-18 13:30:24.651 Primary Thread ID: 5800 | 2022-03-18 13:30:24.651 Usage end date: 2022-08-19 | 2022-03-18 13:30:24.651 Enabled for: Sierra Chart Historical Data Service. | 2022-03-18 13:30:24.651 Enabled for: Delayed Denali Exchange Data Feed. | 2022-03-18 13:30:24.651 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-03-18 13:30:24.651 Current selected Data/Trading service: TransAct WS | 2022-03-18 13:30:24.652 Custom symbol settings values: disabled | 2022-03-18 13:30:24.652 Chart Update Interval: 500 | 2022-03-18 13:30:24.652 Intraday Data Storage Time Unit: 1 | 2022-03-18 13:30:24.652 Time Zone: +00:00:00 (UTC+00) | 2022-03-18 13:30:24.652 2022-03-18 13:30:24 Local computer time in UTC | 2022-03-18 13:30:24.652 2022-03-18 13:30:24 Local computer time in SC Time Zone | 2022-03-18 13:30:24.652 2022-03-18 13:05:17 Server time in UTC | 2022-03-18 13:30:24.652 Local computer UTC time and Server UTC time difference: 1 seconds. | 2022-03-18 13:30:24.652 Program path: C:\SierraChart\ | 2022-03-18 13:30:24.652 Data Files path: C:\SierraChart\Data\ | 2022-03-18 13:30:24.652 OS Version Number: 10.0 | 2022-03-18 13:30:24.652 Locale Setting: C | 2022-03-18 13:30:24.652 DLLs: UserContributedStudies_64.dll | 2022-03-18 13:30:24.652 Allowed protected custom studies: | 2022-03-18 13:30:24.652 File >> Disconnect selected. | 2022-03-18 13:30:32.986 TransAct WS | Session key cleared | 2022-03-18 13:30:32.986 TransAct WS | Disconnected. | 2022-03-18 13:30:32.986 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:35.416 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:35.416 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:35.416 Auth Websocket socket (1) | New receive buffer size: 5242880 | 2022-03-18 13:30:35.416 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:35.416 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:35.461 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:35.461 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:35.590 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:35.590 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:35.590 Auth Websocket | Server header | Sec-WebSocket-Accept: C1NUDKwohbPfOJJ2ylvkw0FGiqQ= | 2022-03-18 13:30:35.590 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:35.590 Auth Websocket | Server header | | 2022-03-18 13:30:35.590 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:35.590 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:35.590 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:35.682 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:35.682 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:35.682 TransAct WS | Session key cleared | 2022-03-18 13:30:35.722 Auth Websocket socket (1) | CloseSocket call. | 2022-03-18 13:30:35.722 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:35.722 TransAct WS | Disconnected. | 2022-03-18 13:30:35.722 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:35.722 Auth Websocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:35.722 Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:35.759 Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:35.759 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:36.717 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:36.717 Auth Websocket socket (3) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:36.717 Auth Websocket socket (3) | New receive buffer size: 5242880 | 2022-03-18 13:30:36.718 Auth Websocket socket (3) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:36.718 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:36.758 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:36.758 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:37.148 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:37.148 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:37.148 Auth Websocket | Server header | Sec-WebSocket-Accept: XyixxaQ0LEfavy/3AAVm92QkwZk= | 2022-03-18 13:30:37.148 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:37.148 Auth Websocket | Server header | | 2022-03-18 13:30:37.148 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:37.148 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:37.148 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:37.237 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:37.237 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:37.237 TransAct WS | Session key cleared | 2022-03-18 13:30:37.247 Auth Websocket socket (3) | CloseSocket call. | 2022-03-18 13:30:37.247 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:37.247 TransAct WS | Disconnected. | 2022-03-18 13:30:37.247 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:37.247 Auth Websocket socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:37.247 Auth Websocket socket (3) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:37.283 Auth Websocket socket (3) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:37.283 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:38.246 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:38.246 Auth Websocket socket (4) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:38.246 Auth Websocket socket (4) | New receive buffer size: 5242880 | 2022-03-18 13:30:38.246 Auth Websocket socket (4) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:38.246 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:38.285 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:38.285 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:38.417 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:38.417 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:38.417 Auth Websocket | Server header | Sec-WebSocket-Accept: QwdnJF4mnUyvRwu9xu1C/RcXyxY= | 2022-03-18 13:30:38.417 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:38.417 Auth Websocket | Server header | | 2022-03-18 13:30:38.417 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:38.417 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:38.417 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:38.505 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:38.505 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:38.505 TransAct WS | Session key cleared | 2022-03-18 13:30:38.517 Auth Websocket socket (4) | CloseSocket call. | 2022-03-18 13:30:38.517 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:38.517 TransAct WS | Disconnected. | 2022-03-18 13:30:38.517 Auth Websocket socket (4) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:38.517 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:38.517 Auth Websocket socket (4) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:38.554 Auth Websocket socket (4) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:38.554 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:39.516 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:39.516 Auth Websocket socket (5) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:39.516 Auth Websocket socket (5) | New receive buffer size: 5242880 | 2022-03-18 13:30:39.516 Auth Websocket socket (5) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:39.516 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:39.555 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:39.555 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:39.683 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:39.683 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:39.683 Auth Websocket | Server header | Sec-WebSocket-Accept: bOCNnjvx94Q6yeZ8SRsvvvt7a5k= | 2022-03-18 13:30:39.683 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:39.683 Auth Websocket | Server header | | 2022-03-18 13:30:39.683 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:39.683 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:39.683 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:39.770 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:39.770 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:39.771 TransAct WS | Session key cleared | 2022-03-18 13:30:39.776 Auth Websocket socket (5) | CloseSocket call. | 2022-03-18 13:30:39.776 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:39.776 TransAct WS | Disconnected. | 2022-03-18 13:30:39.776 Auth Websocket socket (5) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:39.776 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:39.776 Auth Websocket socket (5) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:39.812 Auth Websocket socket (5) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:39.813 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:40.770 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:40.770 Auth Websocket socket (6) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:40.770 Auth Websocket socket (6) | New receive buffer size: 5242880 | 2022-03-18 13:30:40.770 Auth Websocket socket (6) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:40.770 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:40.798 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:40.798 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:40.889 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:40.889 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:40.889 Auth Websocket | Server header | Sec-WebSocket-Accept: 3n1W0sjBJHW77EZTidFY4CMIqgo= | 2022-03-18 13:30:40.889 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:40.889 Auth Websocket | Server header | | 2022-03-18 13:30:40.889 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:40.889 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:40.889 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:40.970 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:40.970 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:40.970 TransAct WS | Session key cleared | 2022-03-18 13:30:40.978 Auth Websocket socket (6) | CloseSocket call. | 2022-03-18 13:30:40.978 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:40.978 TransAct WS | Disconnected. | 2022-03-18 13:30:40.978 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:40.978 Auth Websocket socket (6) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:40.978 Auth Websocket socket (6) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:41.000 Auth Websocket socket (6) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:41.000 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:41.977 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:41.977 Auth Websocket socket (7) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:41.977 Auth Websocket socket (7) | New receive buffer size: 5242880 | 2022-03-18 13:30:41.977 Auth Websocket socket (7) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:41.977 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:42.002 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:42.002 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:42.097 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:42.097 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:42.097 Auth Websocket | Server header | Sec-WebSocket-Accept: OvIONgGDG7z6/0t8dDHMgyPiokU= | 2022-03-18 13:30:42.097 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:42.097 Auth Websocket | Server header | | 2022-03-18 13:30:42.097 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:42.097 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:42.097 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:42.176 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:42.176 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:42.176 TransAct WS | Session key cleared | 2022-03-18 13:30:42.185 Auth Websocket socket (7) | CloseSocket call. | 2022-03-18 13:30:42.185 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:42.185 TransAct WS | Disconnected. | 2022-03-18 13:30:42.185 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:42.185 Auth Websocket socket (7) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:42.185 Auth Websocket socket (7) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:42.208 Auth Websocket socket (7) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:42.208 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:43.185 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:43.185 Auth Websocket socket (8) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:43.186 Auth Websocket socket (8) | New receive buffer size: 5242880 | 2022-03-18 13:30:43.187 Auth Websocket socket (8) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:43.187 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:43.215 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:43.215 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:43.299 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:43.299 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:43.299 Auth Websocket | Server header | Sec-WebSocket-Accept: l74Fv7JPGPQr0pnmPmxlCXvnqDs= | 2022-03-18 13:30:43.300 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:43.300 Auth Websocket | Server header | | 2022-03-18 13:30:43.300 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:43.300 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:43.300 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:43.374 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:43.374 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:43.374 TransAct WS | Session key cleared | 2022-03-18 13:30:43.377 Auth Websocket socket (8) | CloseSocket call. | 2022-03-18 13:30:43.377 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:43.377 TransAct WS | Disconnected. | 2022-03-18 13:30:43.377 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:43.377 Auth Websocket socket (8) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:43.377 Auth Websocket socket (8) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:43.399 Auth Websocket socket (8) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:43.400 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:44.392 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:44.392 Auth Websocket socket (9) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:44.392 Auth Websocket socket (9) | New receive buffer size: 5242880 | 2022-03-18 13:30:44.392 Auth Websocket socket (9) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:44.392 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:44.417 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:44.417 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:44.507 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:44.507 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:44.507 Auth Websocket | Server header | Sec-WebSocket-Accept: 2HF+t+L1eIa6N9TRxgA30DtdW1c= | 2022-03-18 13:30:44.507 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:44.507 Auth Websocket | Server header | | 2022-03-18 13:30:44.507 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:44.507 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:44.507 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:44.582 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:44.582 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:44.582 TransAct WS | Session key cleared | 2022-03-18 13:30:44.584 Auth Websocket socket (9) | CloseSocket call. | 2022-03-18 13:30:44.584 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:44.584 TransAct WS | Disconnected. | 2022-03-18 13:30:44.584 Auth Websocket socket (9) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:44.585 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:44.585 Auth Websocket socket (9) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:44.608 Auth Websocket socket (9) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:44.608 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:45.578 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:45.578 Auth Websocket socket (10) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:45.579 Auth Websocket socket (10) | New receive buffer size: 5242880 | 2022-03-18 13:30:45.579 Auth Websocket socket (10) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:45.579 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:45.603 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:45.603 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:45.695 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:45.695 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:45.695 Auth Websocket | Server header | Sec-WebSocket-Accept: 1+/+t9uidi2g/KSSzMX7WinvmgI= | 2022-03-18 13:30:45.695 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:45.695 Auth Websocket | Server header | | 2022-03-18 13:30:45.695 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:45.695 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:45.695 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:45.771 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:45.771 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:45.771 TransAct WS | Session key cleared | 2022-03-18 13:30:45.791 Auth Websocket socket (10) | CloseSocket call. | 2022-03-18 13:30:45.792 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:45.792 TransAct WS | Disconnected. | 2022-03-18 13:30:45.792 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:45.792 Auth Websocket socket (10) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:45.792 Auth Websocket socket (10) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:45.813 Auth Websocket socket (10) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:45.814 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:46.802 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:46.802 Auth Websocket socket (11) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:46.802 Auth Websocket socket (11) | New receive buffer size: 5242880 | 2022-03-18 13:30:46.803 Auth Websocket socket (11) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:46.803 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:46.832 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:46.832 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:46.921 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:46.921 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:46.921 Auth Websocket | Server header | Sec-WebSocket-Accept: kKlHrGIZpsNJbqse/nLvbAIjJik= | 2022-03-18 13:30:46.921 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:46.921 Auth Websocket | Server header | | 2022-03-18 13:30:46.921 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:46.921 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:46.921 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:46.998 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:46.998 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:46.998 TransAct WS | Session key cleared | 2022-03-18 13:30:47.009 Auth Websocket socket (11) | CloseSocket call. | 2022-03-18 13:30:47.009 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:47.009 TransAct WS | Disconnected. | 2022-03-18 13:30:47.009 Auth Websocket socket (11) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:47.009 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:47.009 Auth Websocket socket (11) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:47.037 Auth Websocket socket (11) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:47.037 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:48.008 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:48.008 Auth Websocket socket (12) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:48.008 Auth Websocket socket (12) | New receive buffer size: 5242880 | 2022-03-18 13:30:48.009 Auth Websocket socket (12) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:48.009 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:48.033 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:48.033 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:48.114 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:48.114 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:48.114 Auth Websocket | Server header | Sec-WebSocket-Accept: Q88+xOjtovna2pa+DWk2fbj4Cds= | 2022-03-18 13:30:48.114 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:48.114 Auth Websocket | Server header | | 2022-03-18 13:30:48.114 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:48.114 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:48.114 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:48.188 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:48.188 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:48.188 TransAct WS | Session key cleared | 2022-03-18 13:30:48.201 Auth Websocket socket (12) | CloseSocket call. | 2022-03-18 13:30:48.201 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:48.201 TransAct WS | Disconnected. | 2022-03-18 13:30:48.201 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:48.201 Auth Websocket socket (12) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:48.201 Auth Websocket socket (12) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:48.223 Auth Websocket socket (12) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:48.224 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:49.200 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:49.200 Auth Websocket socket (13) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:49.201 Auth Websocket socket (13) | New receive buffer size: 5242880 | 2022-03-18 13:30:49.201 Auth Websocket socket (13) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:49.201 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:49.243 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:49.243 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:49.367 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:49.367 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:49.367 Auth Websocket | Server header | Sec-WebSocket-Accept: fttO7r2GhHOcf/7yuIrQIyiw1Wk= | 2022-03-18 13:30:49.367 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:49.367 Auth Websocket | Server header | | 2022-03-18 13:30:49.367 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:49.367 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:49.367 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:49.456 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:49.456 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:49.456 TransAct WS | Session key cleared | 2022-03-18 13:30:49.470 Auth Websocket socket (13) | CloseSocket call. | 2022-03-18 13:30:49.470 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:49.470 Auth Websocket socket (13) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:49.471 TransAct WS | Disconnected. | 2022-03-18 13:30:49.471 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:49.471 Auth Websocket socket (13) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:49.506 Auth Websocket socket (13) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:49.506 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:50.485 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:50.485 Auth Websocket socket (14) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:50.485 Auth Websocket socket (14) | New receive buffer size: 5242880 | 2022-03-18 13:30:50.485 Auth Websocket socket (14) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:50.486 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:50.525 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:50.525 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:50.654 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:50.654 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:50.654 Auth Websocket | Server header | Sec-WebSocket-Accept: QFi8Xt5Rjz2yVkPf6HhfEjurTe0= | 2022-03-18 13:30:50.654 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:50.654 Auth Websocket | Server header | | 2022-03-18 13:30:50.654 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:50.654 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:50.654 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:50.744 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:50.745 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:50.745 TransAct WS | Session key cleared | 2022-03-18 13:30:50.746 Auth Websocket socket (14) | CloseSocket call. | 2022-03-18 13:30:50.746 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:50.746 TransAct WS | Disconnected. | 2022-03-18 13:30:50.746 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:50.746 Auth Websocket socket (14) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:50.746 Auth Websocket socket (14) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:50.781 Auth Websocket socket (14) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:50.782 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:51.740 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:51.740 Auth Websocket socket (15) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:51.741 Auth Websocket socket (15) | New receive buffer size: 5242880 | 2022-03-18 13:30:51.741 Auth Websocket socket (15) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:51.741 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:51.783 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:51.783 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:51.916 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:51.916 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:51.916 Auth Websocket | Server header | Sec-WebSocket-Accept: 3mW+Kqw5wKncHqTrmTldRdXPyX0= | 2022-03-18 13:30:51.916 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:51.916 Auth Websocket | Server header | | 2022-03-18 13:30:51.916 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:51.916 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:51.916 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:52.007 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:52.007 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:52.007 TransAct WS | Session key cleared | 2022-03-18 13:30:52.015 Auth Websocket socket (15) | CloseSocket call. | 2022-03-18 13:30:52.016 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:52.016 TransAct WS | Disconnected. | 2022-03-18 13:30:52.016 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:52.016 Auth Websocket socket (15) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:52.016 Auth Websocket socket (15) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:52.053 Auth Websocket socket (15) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:52.053 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:53.026 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:53.026 Auth Websocket socket (16) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:53.027 Auth Websocket socket (16) | New receive buffer size: 5242880 | 2022-03-18 13:30:53.027 Auth Websocket socket (16) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:53.027 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:53.069 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:53.069 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:53.198 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:53.198 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:53.198 Auth Websocket | Server header | Sec-WebSocket-Accept: NJzz2rCpSWc6UTR7VBjwxi5xDc4= | 2022-03-18 13:30:53.198 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:53.198 Auth Websocket | Server header | | 2022-03-18 13:30:53.198 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:53.198 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:53.198 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:53.287 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:53.288 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:53.288 TransAct WS | Session key cleared | 2022-03-18 13:30:53.301 Auth Websocket socket (16) | CloseSocket call. | 2022-03-18 13:30:53.301 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:53.301 TransAct WS | Disconnected. | 2022-03-18 13:30:53.301 Auth Websocket socket (16) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:53.302 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:53.302 Auth Websocket socket (16) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:53.337 Auth Websocket socket (16) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:53.337 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:54.317 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:54.317 Auth Websocket socket (17) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:54.318 Auth Websocket socket (17) | New receive buffer size: 5242880 | 2022-03-18 13:30:54.318 Auth Websocket socket (17) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:54.318 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:54.348 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:54.348 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:54.430 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:54.430 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:54.430 Auth Websocket | Server header | Sec-WebSocket-Accept: F6WC8vAE9lrfj4yVlbh56oa492Q= | 2022-03-18 13:30:54.430 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:54.430 Auth Websocket | Server header | | 2022-03-18 13:30:54.430 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:54.430 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:54.430 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:54.507 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:54.507 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:54.508 TransAct WS | Session key cleared | 2022-03-18 13:30:54.510 Auth Websocket socket (17) | CloseSocket call. | 2022-03-18 13:30:54.510 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:54.510 TransAct WS | Disconnected. | 2022-03-18 13:30:54.510 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:54.510 Auth Websocket socket (17) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:54.510 Auth Websocket socket (17) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:54.533 Auth Websocket socket (17) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:54.533 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:55.503 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:55.503 Auth Websocket socket (18) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:55.504 Auth Websocket socket (18) | New receive buffer size: 5242880 | 2022-03-18 13:30:55.504 Auth Websocket socket (18) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:55.504 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:55.532 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:55.532 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:55.624 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:55.624 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:55.625 Auth Websocket | Server header | Sec-WebSocket-Accept: n5idWfuIrCdceRBCP9dTcrB/ijU= | 2022-03-18 13:30:55.625 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:55.625 Auth Websocket | Server header | | 2022-03-18 13:30:55.625 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:55.625 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:55.625 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:55.700 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:55.700 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:55.700 TransAct WS | Session key cleared | 2022-03-18 13:30:55.716 Auth Websocket socket (18) | CloseSocket call. | 2022-03-18 13:30:55.716 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:55.716 TransAct WS | Disconnected. | 2022-03-18 13:30:55.716 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:55.716 Auth Websocket socket (18) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:55.716 Auth Websocket socket (18) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:55.740 Auth Websocket socket (18) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:55.740 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:56.711 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:56.711 Auth Websocket socket (19) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:56.711 Auth Websocket socket (19) | New receive buffer size: 5242880 | 2022-03-18 13:30:56.712 Auth Websocket socket (19) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:56.712 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:56.740 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:56.740 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:56.831 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:56.831 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:56.831 Auth Websocket | Server header | Sec-WebSocket-Accept: 5ICWR7GFqvrMmt1Za7tgRwAA8Mc= | 2022-03-18 13:30:56.831 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:56.831 Auth Websocket | Server header | | 2022-03-18 13:30:56.831 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:56.831 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:56.831 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:56.909 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:56.909 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:56.909 TransAct WS | Session key cleared | 2022-03-18 13:30:56.918 Auth Websocket socket (19) | CloseSocket call. | 2022-03-18 13:30:56.918 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:56.918 TransAct WS | Disconnected. | 2022-03-18 13:30:56.918 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:56.919 Auth Websocket socket (19) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:56.919 Auth Websocket socket (19) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:56.942 Auth Websocket socket (19) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:56.942 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:57.934 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:57.934 Auth Websocket socket (20) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:57.934 Auth Websocket socket (20) | New receive buffer size: 5242880 | 2022-03-18 13:30:57.935 Auth Websocket socket (20) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:57.935 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:57.966 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:57.966 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:58.044 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:58.044 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:58.044 Auth Websocket | Server header | Sec-WebSocket-Accept: wi8fks/LWup02I3XYUn0+5Kq4Ro= | 2022-03-18 13:30:58.044 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:58.044 Auth Websocket | Server header | | 2022-03-18 13:30:58.044 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:58.044 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:58.044 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:58.118 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:58.118 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:58.118 TransAct WS | Session key cleared | 2022-03-18 13:30:58.126 Auth Websocket socket (20) | CloseSocket call. | 2022-03-18 13:30:58.126 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:58.126 TransAct WS | Disconnected. | 2022-03-18 13:30:58.126 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:58.126 Auth Websocket socket (20) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:58.126 Auth Websocket socket (20) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:58.148 Auth Websocket socket (20) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:58.148 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:30:59.125 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:30:59.125 Auth Websocket socket (21) | Creating socket. Using TLS 1.2. | 2022-03-18 13:30:59.126 Auth Websocket socket (21) | New receive buffer size: 5242880 | 2022-03-18 13:30:59.126 Auth Websocket socket (21) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:30:59.126 Auth Websocket | Opening WebSocket. | 2022-03-18 13:30:59.151 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:30:59.152 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:30:59.236 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:30:59.236 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:30:59.236 Auth Websocket | Server header | Sec-WebSocket-Accept: GcWVivAkghAbUFPsDX8Y56pGBX8= | 2022-03-18 13:30:59.236 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:30:59.236 Auth Websocket | Server header | | 2022-03-18 13:30:59.237 Auth Websocket | Web socket state is now open. | 2022-03-18 13:30:59.237 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:30:59.237 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:30:59.311 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:30:59.311 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:59.311 TransAct WS | Session key cleared | 2022-03-18 13:30:59.317 Auth Websocket socket (21) | CloseSocket call. | 2022-03-18 13:30:59.318 Auth Websocket | WebSocket closed. | 2022-03-18 13:30:59.318 TransAct WS | Disconnected. | 2022-03-18 13:30:59.318 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:30:59.318 Auth Websocket socket (21) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:30:59.318 Auth Websocket socket (21) | Write has completed. Shutdown being performed. | 2022-03-18 13:30:59.345 Auth Websocket socket (21) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:30:59.345 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:31:00.333 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:31:00.333 Auth Websocket socket (22) | Creating socket. Using TLS 1.2. | 2022-03-18 13:31:00.333 Auth Websocket socket (22) | New receive buffer size: 5242880 | 2022-03-18 13:31:00.334 Auth Websocket socket (22) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:31:00.334 Auth Websocket | Opening WebSocket. | 2022-03-18 13:31:00.358 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:31:00.358 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:31:00.444 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:31:00.444 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:31:00.444 Auth Websocket | Server header | Sec-WebSocket-Accept: VzRVZ3HdLSz31xlM0Zas3PyAPBU= | 2022-03-18 13:31:00.444 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:31:00.445 Auth Websocket | Server header | | 2022-03-18 13:31:00.445 Auth Websocket | Web socket state is now open. | 2022-03-18 13:31:00.445 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:31:00.445 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:31:00.519 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:31:00.519 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:00.519 TransAct WS | Session key cleared | 2022-03-18 13:31:00.525 Auth Websocket socket (22) | CloseSocket call. | 2022-03-18 13:31:00.525 Auth Websocket | WebSocket closed. | 2022-03-18 13:31:00.525 TransAct WS | Disconnected. | 2022-03-18 13:31:00.525 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:00.525 Auth Websocket socket (22) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:31:00.525 Auth Websocket socket (22) | Write has completed. Shutdown being performed. | 2022-03-18 13:31:00.547 Auth Websocket socket (22) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:31:00.548 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:31:01.520 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:31:01.520 Auth Websocket socket (23) | Creating socket. Using TLS 1.2. | 2022-03-18 13:31:01.520 Auth Websocket socket (23) | New receive buffer size: 5242880 | 2022-03-18 13:31:01.521 Auth Websocket socket (23) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:31:01.521 Auth Websocket | Opening WebSocket. | 2022-03-18 13:31:01.552 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:31:01.552 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:31:01.635 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:31:01.635 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:31:01.635 Auth Websocket | Server header | Sec-WebSocket-Accept: 7sHu3OlJS5Ua37hd2Vg3/FoVEbI= | 2022-03-18 13:31:01.635 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:31:01.635 Auth Websocket | Server header | | 2022-03-18 13:31:01.635 Auth Websocket | Web socket state is now open. | 2022-03-18 13:31:01.635 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:31:01.635 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:31:01.710 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:31:01.710 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:01.710 TransAct WS | Session key cleared | 2022-03-18 13:31:01.717 Auth Websocket socket (23) | CloseSocket call. | 2022-03-18 13:31:01.717 Auth Websocket | WebSocket closed. | 2022-03-18 13:31:01.717 TransAct WS | Disconnected. | 2022-03-18 13:31:01.717 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:01.717 Auth Websocket socket (23) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:31:01.717 Auth Websocket socket (23) | Write has completed. Shutdown being performed. | 2022-03-18 13:31:01.741 Auth Websocket socket (23) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:31:01.741 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:31:02.712 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:31:02.712 Auth Websocket socket (24) | Creating socket. Using TLS 1.2. | 2022-03-18 13:31:02.712 Auth Websocket socket (24) | New receive buffer size: 5242880 | 2022-03-18 13:31:02.713 Auth Websocket socket (24) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:31:02.713 Auth Websocket | Opening WebSocket. | 2022-03-18 13:31:02.741 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:31:02.741 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:31:02.834 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:31:02.834 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:31:02.834 Auth Websocket | Server header | Sec-WebSocket-Accept: oQIuJ7NzkQbaPOi04PpU/vuCNqk= | 2022-03-18 13:31:02.834 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:31:02.834 Auth Websocket | Server header | | 2022-03-18 13:31:02.834 Auth Websocket | Web socket state is now open. | 2022-03-18 13:31:02.834 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:31:02.834 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:31:02.911 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:31:02.911 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:02.911 TransAct WS | Session key cleared | 2022-03-18 13:31:02.919 Auth Websocket socket (24) | CloseSocket call. | 2022-03-18 13:31:02.919 Auth Websocket | WebSocket closed. | 2022-03-18 13:31:02.919 TransAct WS | Disconnected. | 2022-03-18 13:31:02.919 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:02.919 Auth Websocket socket (24) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:31:02.920 Auth Websocket socket (24) | Write has completed. Shutdown being performed. | 2022-03-18 13:31:02.947 Auth Websocket socket (24) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:31:02.948 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:31:03.918 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:31:03.918 Auth Websocket socket (25) | Creating socket. Using TLS 1.2. | 2022-03-18 13:31:03.919 Auth Websocket socket (25) | New receive buffer size: 5242880 | 2022-03-18 13:31:03.919 Auth Websocket socket (25) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:31:03.919 Auth Websocket | Opening WebSocket. | 2022-03-18 13:31:03.961 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:31:03.961 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:31:04.096 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:31:04.096 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:31:04.096 Auth Websocket | Server header | Sec-WebSocket-Accept: y+P3Biat4pJB4Gvmae7UbgbU3wU= | 2022-03-18 13:31:04.096 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:31:04.096 Auth Websocket | Server header | | 2022-03-18 13:31:04.096 Auth Websocket | Web socket state is now open. | 2022-03-18 13:31:04.096 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:31:04.096 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:31:04.186 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:31:04.186 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:04.186 TransAct WS | Session key cleared | 2022-03-18 13:31:04.194 Auth Websocket socket (25) | CloseSocket call. | 2022-03-18 13:31:04.194 Auth Websocket | WebSocket closed. | 2022-03-18 13:31:04.194 TransAct WS | Disconnected. | 2022-03-18 13:31:04.194 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:04.194 Auth Websocket socket (25) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:31:04.194 Auth Websocket socket (25) | Write has completed. Shutdown being performed. | 2022-03-18 13:31:04.500 Auth Websocket socket (25) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:31:04.500 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:31:05.204 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:31:05.204 Auth Websocket socket (26) | Creating socket. Using TLS 1.2. | 2022-03-18 13:31:05.205 Auth Websocket socket (26) | New receive buffer size: 5242880 | 2022-03-18 13:31:05.205 Auth Websocket socket (26) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:31:05.206 Auth Websocket | Opening WebSocket. | 2022-03-18 13:31:05.247 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:31:05.247 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:31:05.370 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:31:05.370 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:31:05.370 Auth Websocket | Server header | Sec-WebSocket-Accept: vhuU4mdIjNXA4eTeTXwaXiACODQ= | 2022-03-18 13:31:05.370 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:31:05.370 Auth Websocket | Server header | | 2022-03-18 13:31:05.370 Auth Websocket | Web socket state is now open. | 2022-03-18 13:31:05.370 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:31:05.370 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:31:05.459 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:31:05.459 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:05.459 TransAct WS | Session key cleared | 2022-03-18 13:31:05.464 Auth Websocket socket (26) | CloseSocket call. | 2022-03-18 13:31:05.464 Auth Websocket | WebSocket closed. | 2022-03-18 13:31:05.464 TransAct WS | Disconnected. | 2022-03-18 13:31:05.464 Auth Websocket socket (26) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:31:05.464 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:05.464 Auth Websocket socket (26) | Write has completed. Shutdown being performed. | 2022-03-18 13:31:05.500 Auth Websocket socket (26) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:31:05.500 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:31:06.474 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:31:06.474 Auth Websocket socket (27) | Creating socket. Using TLS 1.2. | 2022-03-18 13:31:06.474 Auth Websocket socket (27) | New receive buffer size: 5242880 | 2022-03-18 13:31:06.474 Auth Websocket socket (27) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:31:06.474 Auth Websocket | Opening WebSocket. | 2022-03-18 13:31:06.515 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:31:06.515 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:31:06.646 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:31:06.646 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:31:06.646 Auth Websocket | Server header | Sec-WebSocket-Accept: ActdarkoSpH7hxaPl08y4dPFJ5I= | 2022-03-18 13:31:06.646 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:31:06.646 Auth Websocket | Server header | | 2022-03-18 13:31:06.646 Auth Websocket | Web socket state is now open. | 2022-03-18 13:31:06.646 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:31:06.646 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:31:06.987 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:31:06.987 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:06.987 TransAct WS | Session key cleared | 2022-03-18 13:31:06.989 Auth Websocket socket (27) | CloseSocket call. | 2022-03-18 13:31:06.989 Auth Websocket | WebSocket closed. | 2022-03-18 13:31:06.989 TransAct WS | Disconnected. | 2022-03-18 13:31:06.989 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:06.989 Auth Websocket socket (27) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:31:06.990 Auth Websocket socket (27) | Write has completed. Shutdown being performed. | 2022-03-18 13:31:07.025 Auth Websocket socket (27) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:31:07.025 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:31:07.988 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:31:07.988 Auth Websocket socket (28) | Creating socket. Using TLS 1.2. | 2022-03-18 13:31:07.988 Auth Websocket socket (28) | New receive buffer size: 5242880 | 2022-03-18 13:31:07.989 Auth Websocket socket (28) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:31:07.989 Auth Websocket | Opening WebSocket. | 2022-03-18 13:31:08.030 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:31:08.030 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:31:08.156 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:31:08.156 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:31:08.157 Auth Websocket | Server header | Sec-WebSocket-Accept: tyy3aP8FEvIHHGWlAO9YqMaF9qU= | 2022-03-18 13:31:08.157 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:31:08.157 Auth Websocket | Server header | | 2022-03-18 13:31:08.157 Auth Websocket | Web socket state is now open. | 2022-03-18 13:31:08.157 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:31:08.157 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:31:08.247 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:31:08.247 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:08.247 TransAct WS | Session key cleared | 2022-03-18 13:31:08.264 Auth Websocket socket (28) | CloseSocket call. | 2022-03-18 13:31:08.264 Auth Websocket | WebSocket closed. | 2022-03-18 13:31:08.264 TransAct WS | Disconnected. | 2022-03-18 13:31:08.264 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:08.264 Auth Websocket socket (28) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:31:08.264 Auth Websocket socket (28) | Write has completed. Shutdown being performed. | 2022-03-18 13:31:08.301 Auth Websocket socket (28) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:31:08.301 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:31:09.258 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:31:09.258 Auth Websocket socket (29) | Creating socket. Using TLS 1.2. | 2022-03-18 13:31:09.258 Auth Websocket socket (29) | New receive buffer size: 5242880 | 2022-03-18 13:31:09.259 Auth Websocket socket (29) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:31:09.259 Auth Websocket | Opening WebSocket. | 2022-03-18 13:31:09.285 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:31:09.285 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:31:09.368 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:31:09.368 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:31:09.368 Auth Websocket | Server header | Sec-WebSocket-Accept: Go36nHijfCghOOR6LkFPQDbNhoE= | 2022-03-18 13:31:09.368 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:31:09.368 Auth Websocket | Server header | | 2022-03-18 13:31:09.368 Auth Websocket | Web socket state is now open. | 2022-03-18 13:31:09.368 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:31:09.368 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:31:09.444 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:31:09.444 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:09.444 TransAct WS | Session key cleared | 2022-03-18 13:31:09.450 Auth Websocket socket (29) | CloseSocket call. | 2022-03-18 13:31:09.450 Auth Websocket | WebSocket closed. | 2022-03-18 13:31:09.450 TransAct WS | Disconnected. | 2022-03-18 13:31:09.451 Auth Websocket socket (29) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:31:09.451 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:09.451 Auth Websocket socket (29) | Write has completed. Shutdown being performed. | 2022-03-18 13:31:09.472 Auth Websocket socket (29) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:31:09.472 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:31:10.449 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:31:10.449 Auth Websocket socket (30) | Creating socket. Using TLS 1.2. | 2022-03-18 13:31:10.449 Auth Websocket socket (30) | New receive buffer size: 5242880 | 2022-03-18 13:31:10.450 Auth Websocket socket (30) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:31:10.450 Auth Websocket | Opening WebSocket. | 2022-03-18 13:31:10.474 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:31:10.474 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:31:10.563 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:31:10.563 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:31:10.563 Auth Websocket | Server header | Sec-WebSocket-Accept: n9V4QIt4DuziOyAhMHljVtdNJaw= | 2022-03-18 13:31:10.563 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:31:10.563 Auth Websocket | Server header | | 2022-03-18 13:31:10.563 Auth Websocket | Web socket state is now open. | 2022-03-18 13:31:10.563 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:31:10.563 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:31:10.642 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:31:10.642 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:10.642 TransAct WS | Session key cleared | 2022-03-18 13:31:10.658 Auth Websocket socket (30) | CloseSocket call. | 2022-03-18 13:31:10.658 Auth Websocket | WebSocket closed. | 2022-03-18 13:31:10.658 TransAct WS | Disconnected. | 2022-03-18 13:31:10.658 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:10.658 Auth Websocket socket (30) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:31:10.658 Auth Websocket socket (30) | Write has completed. Shutdown being performed. | 2022-03-18 13:31:10.680 Auth Websocket socket (30) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:31:10.680 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:31:11.657 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:31:11.657 Auth Websocket socket (31) | Creating socket. Using TLS 1.2. | 2022-03-18 13:31:11.658 Auth Websocket socket (31) | New receive buffer size: 5242880 | 2022-03-18 13:31:11.658 Auth Websocket socket (31) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:31:11.658 Auth Websocket | Opening WebSocket. | 2022-03-18 13:31:11.686 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:31:11.686 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:31:11.769 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:31:11.769 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:31:11.769 Auth Websocket | Server header | Sec-WebSocket-Accept: QE2dGmbL4goTAVcpY348ThEbo/A= | 2022-03-18 13:31:11.769 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:31:11.769 Auth Websocket | Server header | | 2022-03-18 13:31:11.769 Auth Websocket | Web socket state is now open. | 2022-03-18 13:31:11.769 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:31:11.769 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:31:11.850 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:31:11.850 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:11.850 TransAct WS | Session key cleared | 2022-03-18 13:31:11.865 Auth Websocket socket (31) | CloseSocket call. | 2022-03-18 13:31:11.865 Auth Websocket | WebSocket closed. | 2022-03-18 13:31:11.865 TransAct WS | Disconnected. | 2022-03-18 13:31:11.865 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:11.865 Auth Websocket socket (31) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:31:11.865 Auth Websocket socket (31) | Write has completed. Shutdown being performed. | 2022-03-18 13:31:11.887 Auth Websocket socket (31) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:31:11.887 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:31:12.864 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:31:12.864 Auth Websocket socket (32) | Creating socket. Using TLS 1.2. | 2022-03-18 13:31:12.864 Auth Websocket socket (32) | New receive buffer size: 5242880 | 2022-03-18 13:31:12.865 Auth Websocket socket (32) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:31:12.865 Auth Websocket | Opening WebSocket. | 2022-03-18 13:31:12.892 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:31:12.892 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:31:12.979 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:31:12.979 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:31:12.979 Auth Websocket | Server header | Sec-WebSocket-Accept: 14VbbwkgHOwkmjowbK0hxZz6WBg= | 2022-03-18 13:31:12.979 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:31:12.979 Auth Websocket | Server header | | 2022-03-18 13:31:12.979 Auth Websocket | Web socket state is now open. | 2022-03-18 13:31:12.979 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:31:12.979 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:31:13.057 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:31:13.057 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:13.057 TransAct WS | Session key cleared | 2022-03-18 13:31:13.073 Auth Websocket socket (32) | CloseSocket call. | 2022-03-18 13:31:13.073 Auth Websocket | WebSocket closed. | 2022-03-18 13:31:13.073 TransAct WS | Disconnected. | 2022-03-18 13:31:13.073 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:13.073 Auth Websocket socket (32) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:31:13.073 Auth Websocket socket (32) | Write has completed. Shutdown being performed. | 2022-03-18 13:31:13.096 Auth Websocket socket (32) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:31:13.096 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:31:14.082 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:31:14.082 Auth Websocket socket (33) | Creating socket. Using TLS 1.2. | 2022-03-18 13:31:14.083 Auth Websocket socket (33) | New receive buffer size: 5242880 | 2022-03-18 13:31:14.083 Auth Websocket socket (33) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:31:14.083 Auth Websocket | Opening WebSocket. | 2022-03-18 13:31:14.125 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:31:14.125 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:31:14.253 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:31:14.253 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:31:14.253 Auth Websocket | Server header | Sec-WebSocket-Accept: 8cknSBQqcfA3kTUhOX47Rgvi1q0= | 2022-03-18 13:31:14.253 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:31:14.253 Auth Websocket | Server header | | 2022-03-18 13:31:14.253 Auth Websocket | Web socket state is now open. | 2022-03-18 13:31:14.253 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:31:14.253 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:31:14.343 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:31:14.343 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:14.343 TransAct WS | Session key cleared | 2022-03-18 13:31:14.358 Auth Websocket socket (33) | CloseSocket call. | 2022-03-18 13:31:14.358 Auth Websocket | WebSocket closed. | 2022-03-18 13:31:14.358 TransAct WS | Disconnected. | 2022-03-18 13:31:14.358 Auth Websocket socket (33) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:31:14.358 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:14.358 Auth Websocket socket (33) | Write has completed. Shutdown being performed. | 2022-03-18 13:31:14.401 Auth Websocket socket (33) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:31:14.402 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:31:15.357 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:31:15.357 Auth Websocket socket (34) | Creating socket. Using TLS 1.2. | 2022-03-18 13:31:15.358 Auth Websocket socket (34) | New receive buffer size: 5242880 | 2022-03-18 13:31:15.358 Auth Websocket socket (34) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:31:15.358 Auth Websocket | Opening WebSocket. | 2022-03-18 13:31:15.399 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:31:15.399 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:31:15.611 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:31:15.611 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:31:15.611 Auth Websocket | Server header | Sec-WebSocket-Accept: 0uAPQH1qdVXoGR11piZDsJtShc4= | 2022-03-18 13:31:15.611 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:31:15.611 Auth Websocket | Server header | | 2022-03-18 13:31:15.611 Auth Websocket | Web socket state is now open. | 2022-03-18 13:31:15.611 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:31:15.611 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:31:15.701 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:31:15.702 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:15.702 TransAct WS | Session key cleared | 2022-03-18 13:31:15.711 Auth Websocket socket (34) | CloseSocket call. | 2022-03-18 13:31:15.711 Auth Websocket | WebSocket closed. | 2022-03-18 13:31:15.711 TransAct WS | Disconnected. | 2022-03-18 13:31:15.711 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:15.711 Auth Websocket socket (34) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:31:15.711 Auth Websocket socket (34) | Write has completed. Shutdown being performed. | 2022-03-18 13:31:15.747 Auth Websocket socket (34) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:31:15.747 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:31:16.705 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:31:16.705 Auth Websocket socket (35) | Creating socket. Using TLS 1.2. | 2022-03-18 13:31:16.706 Auth Websocket socket (35) | New receive buffer size: 5242880 | 2022-03-18 13:31:16.706 Auth Websocket socket (35) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:31:16.706 Auth Websocket | Opening WebSocket. | 2022-03-18 13:31:16.745 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:31:16.745 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:31:16.881 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:31:16.881 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:31:16.881 Auth Websocket | Server header | Sec-WebSocket-Accept: 3KPmlga0/YUWIBavqvRg4Ca5eyc= | 2022-03-18 13:31:16.881 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:31:16.881 Auth Websocket | Server header | | 2022-03-18 13:31:16.881 Auth Websocket | Web socket state is now open. | 2022-03-18 13:31:16.881 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:31:16.881 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:31:16.970 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:31:16.970 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:16.970 TransAct WS | Session key cleared | 2022-03-18 13:31:16.981 Auth Websocket socket (35) | CloseSocket call. | 2022-03-18 13:31:16.981 Auth Websocket | WebSocket closed. | 2022-03-18 13:31:16.981 TransAct WS | Disconnected. | 2022-03-18 13:31:16.981 Auth Websocket socket (35) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:31:16.981 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:16.981 Auth Websocket socket (35) | Write has completed. Shutdown being performed. | 2022-03-18 13:31:17.017 Auth Websocket socket (35) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:31:17.017 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:31:17.996 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:31:17.996 Auth Websocket socket (36) | Creating socket. Using TLS 1.2. | 2022-03-18 13:31:17.996 Auth Websocket socket (36) | New receive buffer size: 5242880 | 2022-03-18 13:31:17.997 Auth Websocket socket (36) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:31:17.997 Auth Websocket | Opening WebSocket. | 2022-03-18 13:31:18.037 Auth Websocket | Sending WebSocket handshake. | 2022-03-18 13:31:18.037 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-03-18 13:31:18.166 Auth Websocket | Server header | Upgrade: WebSocket | 2022-03-18 13:31:18.166 Auth Websocket | Server header | Connection: Upgrade | 2022-03-18 13:31:18.167 Auth Websocket | Server header | Sec-WebSocket-Accept: tnvYz/0sKVd0WChUT3K8rlqa/gQ= | 2022-03-18 13:31:18.167 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2022-03-18 13:31:18.167 Auth Websocket | Server header | | 2022-03-18 13:31:18.167 Auth Websocket | Web socket state is now open. | 2022-03-18 13:31:18.167 TransAct WS | Sending account logon message. Simulated Live | 2022-03-18 13:31:18.167 TransAct WS | Account logon error: -1(-1) | 2022-03-18 13:31:18.263 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-03-18 13:31:18.263 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:18.263 TransAct WS | Session key cleared | 2022-03-18 13:31:18.266 Auth Websocket socket (36) | CloseSocket call. | 2022-03-18 13:31:18.266 Auth Websocket | WebSocket closed. | 2022-03-18 13:31:18.266 TransAct WS | Disconnected. | 2022-03-18 13:31:18.267 Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-03-18 13:31:18.267 Auth Websocket socket (36) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-03-18 13:31:18.267 Auth Websocket socket (36) | Write has completed. Shutdown being performed. | 2022-03-18 13:31:18.302 Auth Websocket socket (36) | Shutdown started. Waiting for graceful close. | 2022-03-18 13:31:18.303 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2022-03-18 13:31:19.266 Auth Websocket | Connecting to WebSocket server 208.97.219.30:1869 | 2022-03-18 13:31:19.266 Auth Websocket socket (38) | Creating socket. Using TLS 1.2. | 2022-03-18 13:31:19.266 Auth Websocket socket (38) | New receive buffer size: 5242880 | 2022-03-18 13:31:19.267 Auth Websocket socket (38) | Connecting to IP: 208.97.219.30. | 2022-03-18 13:31:19.267 Auth Websocket | Opening WebSocket. | 2022-03-18 13:31:19.294 Auth Websocket | S |
[2022-03-18 15:33:37] |
We can set up access to our Denali Data Feed which you will need anyway for Teton. So at least you can access the market data. What exchanges do you need data for? Or what symbols are you trading. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-18 15:34:15
