Date/Time: Wed, 05 Feb 2025 03:58:55 +0000
Recommended broker for trading both stocks and futures
View Count: 577
[2020-02-27 15:07:52] |
User658075 - Posts: 1 |
Hi, Do you have recommended broker for trading both stocks and futures inside of IB. |
[2020-02-27 18:29:34] |
You would just use Interactive Brokers: Interactive Brokers Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
