Date/Time: Wed, 05 Feb 2025 06:59:16 +0000
odd results when using the
View Count: 686
[2020-02-27 11:37:15]
User178540 - Posts: 15
Hello SC,
I have been using the study: "Write Bar data to file" for a long time to export trades data.
the configuration that I use is:
Number of trades per bar: 1
The odd results are that in many lines appears both BID and ASK volume. sometimes they add to the sum of the Volume (for example BID 1, ASK 1, volume: 2) and sometimes not (for example, BID: 1, ASK: 1, Volume: 1).
This didn't happen with older versions of the study.
Thanks for the help!
Example result lines:
2020/2/25, 21:15:01.11, 3156.50, 3156.75, 3156.50, 3156.75, 2, 1, 3156.63, 3156.67, 3156.63, 1, 2
2020/2/25, 21:15:05.3, 3157.00, 3157.00, 3157.00, 3157.00, 2, 1, 3157.00, 3157.00, 3157.00, 1, 1
[2020-02-27 19:07:15]
We need to see the first-line header from that file which corresponds with those two rows.
Actually really would be best to provide us that chart the study is on by following these instructions:
Date Time Of Last Edit: 2020-02-27 19:08:04
[2020-02-28 00:49:02]
This is the header line:
Date, Time, Open, High, Low, Last, Volume, # of Trades, OHLC Avg, HLC Avg, HL Avg, Bid Volume, Ask Volume
attached the chart.
Private File
[2020-03-05 08:55:49]
Hello SC,
any update on this?
[2020-03-05 09:12:27]
We cannot spend further time on this now. We were unable to reproduce the issue. It will have to be looked into later on.
