Date/Time: Wed, 05 Feb 2025 04:07:38 +0000
Imported .depth file not displayed on the chart
View Count: 552
[2020-02-27 09:51:07]
manfretto - Posts: 117
Hi, I have copied .depth file into Data/marketdepthdata folder. After that I have opened Sierra Chart. When I find and load symbol I do not see any market depth data on the chart.
Some remarks: 'data to load' extended to cover the period with market depth. Market depth is set to 10.
[2020-02-27 18:45:31]
Make sure the depth file matches the exact symbol that you have on your chart. The filename prior to the first period (.) is the symbol that the depth file is for.
Then make sure that you have the chart displaying the day that the depth file is for. There is no way to know what time the depth file covers, so you will need to scroll through the day to find the data.
And then refer to the steps here in regards to this kind of issue:
Market Depth Historical Graph: Market Depth Historical Graph Not Displaying
Date Time Of Last Edit: 2020-02-27 18:46:21
[2020-02-27 18:58:45]
And what if I would like to load symbol which is not available under current Data/Trade service? Is it still feasible?
[2020-03-02 00:20:44]
Sierra_Chart Engineering - Posts: 18262
Just as long as the depth file symbol matches the symbol of the chart.
