Date/Time: Wed, 05 Feb 2025 03:53:27 +0000
Sierra Chart on multiple computers
View Count: 635
[2020-02-26 19:17:11]
JEM.TRADES - Posts: 16
Hi support,
I apologize beforehand for the basic question but I haven’t been able to find a concrete answer.
I’ve been using Sierra Chart for a while on my laptop. I have lots of customization.
I’m also thinking about putting a couple of trades while at work.
If I install Sierra Chart to my work desktop, once I log in, will I have everything showing the same as my laptop?
NOTE: I will not be using my laptop and my work desktop at the same time.
Thank you!
[2020-02-26 23:12:26]
Your Sierra Chart account is expired.
We will only provide support for paid accounts. If you have another account, make sure you log into this support board with Help >> Support Board from within Sierra Chart.
[2020-03-02 00:03:14]
Sierra_Chart Engineering - Posts: 18262
Each Sierra Chart installation is portable and independent and it is easy to transfer/copy installations.
Refer to the following for what you want:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Simple Transfer/Copy of Sierra Chart Installation to Another Folder or Computer System
Note the link at the end of that section for File Sharing, which you may want to use.
