Date/Time: Wed, 05 Feb 2025 04:06:10 +0000
issue image
View Count: 487
[2020-02-26 18:51:02] |
Stupid - Posts: 30 |
File attached.
Sierra Chart MainWindow 2020-02-26 13_48_18.732.png / V - Attached On 2020-02-26 18:50:18 UTC - Size: 113.54 KB - 216 views Attachment Deleted. |
[2020-02-26 20:06:32] |
You have the wrong Service set in Sierra Chart. It needs to SC Futures Order Routing. Follow the steps beginning with step 9 here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
