Date/Time: Wed, 05 Feb 2025 03:47:48 +0000
windows....
View Count: 485
[2020-02-26 17:29:58]
Stupid - Posts: 30
so i if is click window it get hung so i cannot send the log...
[2020-02-26 18:56:53]
We need more information as to what exactly is happening.
What particular window are you opening or activating?
Also enables: Global Settings >> General Settings >> General 2 >> Save Message Log to File. This way, if it is a problem with the program and you are not able to get to the Message Log window, the information will be in a file under your Sierra Chart installation folder. Refer to the following information for that setting:
General Settings Window: Save Message Log to File (Global Settings >> General Settings >> Log >> Log)
Date Time Of Last Edit: 2020-02-26 18:57:05
