Date/Time: Wed, 05 Feb 2025 04:05:07 +0000
For the broker
View Count: 562
[2020-02-26 15:55:03] |
User454090 - Posts: 1 |
Hi, i'm Canadian and the broker i can use it's GFF Broker but i don't see on the lost, it' s possible tout add one ? And i want Trade for topstep, what is the broker i need tout use ? Can i use a both on the same account ? Thank You to answer |
[2020-02-27 18:00:48] |
Yes GFF Brokers is supported. If you want to use Top Step Trader there is no other broker required with them. You can use both with a single Sierra Chart account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-27 18:00:59
