Date/Time: Wed, 05 Feb 2025 04:10:17 +0000
Trade data cleared after Backtest
View Count: 539
[2020-02-26 12:40:32] |
User351605 - Posts: 82 |
Since I updated to version 2054 and I run a backtest, there's no data in my activity log. Although the P/L in the trade window shows activity. I didn't make any changes since my last Backtests with version 2020. What could be the reason? |
[2020-02-26 12:46:05] |
This is probably not the issue, but refer to the instructions here to convert the Trade Activity Log format: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2050 After that make sure you have set the controls on the Trade Activity log properly. Instructions: Trade Activity Log: Viewing Historical Trade Activity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-26 12:46:34
