Date/Time: Wed, 05 Feb 2025 03:59:22 +0000
wrong drawing
View Count: 542
[2020-02-26 09:05:19] |
User491428 - Posts: 87 |
My entries and fillings are drawn with a delay. what is wrong here?
es.bmp - Attached On 2020-02-26 09:04:48 UTC - Size: 6.93 MB - 356 views |
[2020-02-26 13:16:41] |
Update Sierra Chart to the current version: Software Download: Fast Update Also make sure your computer's clock is set correctly: Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
