Date/Time: Wed, 05 Feb 2025 04:01:10 +0000
Chart bars do not update. Price stays current but bars do not.
View Count: 566
[2020-02-26 02:09:07] |
User108483 - Posts: 3 |
I just got the Denali exchange data feed up and running. The current price updates but the bar charts don't, they are static but the price moves as expected. > > My brokerage is Transact futures. > > I opted for the cme group market depth but found I don't want that many depths. I prefer the 10 depths of market that transact supplied. I therefore deactivated the market depth option for the cme group and opted for the cme group w/o market depth, but the market depth still shows up. How do I make that go away? By default do you show market depth of 10 price levels with the cme group option w/o market depth? |
[2020-02-26 02:52:39] |
My mistake, I forgot to display overnight session. Been a long night. I would still like to know via the Denali data feed if it is possible to have a depth of market of only ten prices. |
[2020-02-26 12:43:35] |
To control the number of levels of market depth data, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Controlling Number of Market Depth Levels You will not get any market depth data when you are using a CME exchange that does not include depth. You will just have the top of book only. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-26 12:43:47
