Date/Time: Wed, 05 Feb 2025 04:00:23 +0000
Graphics
View Count: 556
[2020-02-25 21:12:13] |
Ex2590 - Posts: 3 |
I set up a chart with the graphics I wanted for both the chart and studies. If I try to duplicate the setup by using save as, it creates a chart with the old graphics I was using. How can I create new charts duplicating the graphics on my preferred chart?
[2020-02-26 00:27:31] |
Refer to the information here on how to use an existing chart as a template: Using Chart Templates: Duplicating Charts / Template Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-26 00:27:45
