Date/Time: Wed, 05 Feb 2025 03:55:13 +0000
Copying charts to new chartbook
View Count: 1148
[2020-02-25 21:10:14] |
User750920 - Posts: 280 |
Whenever I open a new chartbook and then copy all my charts from an already created chartbook to a the new one the Study to Overlay's do not reference correctly - I need to go in and manually fix all of them. Any way around this. Thanks |
[2020-02-25 23:25:32] |
No there is no way around this because the chart numbers are going to be different. Maybe we could solve this but it is a substantial development item which we simply do not have any time to get to.
[2020-02-26 00:22:28] |
Sawtooth - Posts: 4167 |
You could 'Save As' the chartbook to a new name and everything is duplicated as in the original. Then you could modify the new chartbook as needed. |
[2020-02-26 13:38:07] |
@tomgilb. Cannot believe I didn't think of that as a partial work around to shorten the time spent to do what I want. Thank you.
[2020-02-26 13:39:05] |
@Sierra - thanks and I understand.
