Date/Time: Mon, 25 Nov 2024 02:30:05 +0000
worksheet study, use variable attached stops
View Count: 1115
[2014-01-07 16:34:13] |
pkhst958 - Posts: 57 |
Hi all, I use a worksheet study to trade. The stops are in the Trade Window. How can I transfer with each trade an individual Stop from the worksheet study to the trade window? Thanks, Pit |
[2014-01-07 18:15:15] |
This is documented in this section here: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#AttachedOrderTargetOffset Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
