Date/Time: Tue, 07 May 2024 07:05:59 +0000
Study Simple Alert Syntax Error
View Count: 478
[2020-02-24 15:14:22] |
User565723 - Posts: 3 |
Hello, I'm creating study simple alerts, but log throws a Syntax Error with formulas as basic as =OR(SG1>200,SG1<-200). Even if I copy and paste formulas from your documentation, I get an error. Basicaly every OR or AND formulas throw an error.
[2020-02-25 14:34:26] |
Hello, I've reset SC and now it works just right :)
[2020-02-25 16:57:00] |
It does not make sense resetting Sierra Chart would have any effect upon this. If you have a problem again we need to see the exact error message you are getting.
