Date/Time: Tue, 07 May 2024 15:21:14 +0000
Numbers Bar indicator nor functioning properly onbGlobal data feeds
View Count: 559
[2020-02-24 06:15:55] |
gops1970 - Posts: 2 |
I have installed Sierrachart..Numbers Bars indicator is working fine on instruments supported on Rithmic data. But when i applied the Numbers Bar on instruments(NSE futures like NIFTY-I.NFO) supported by Global Data Feeds data its not functioning at all. They have directed me to your end saying problem with settings. Please help
[2020-02-24 08:03:07] |
Can you please tell us if this is the exact symbol that you are using: NIFTY-I.NFO We will then set up the necessary Symbol Settings for it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-24 08:03:16
[2020-02-24 09:23:31] |
Yes. The other symbol i want settings is BANKNIFTY-I.NFO.Its lot size is 20 while lot size of NIFTY-I.NFO is 75 . so please set the contract size accordingly.. also i would like Tick size of 1 for NIFTY-I.NFO and 2 for BANKNIFTY-I.NFO.
[2020-02-25 09:06:30] |
We have looked into this, and we have already defined Symbol Settings for these symbols. We want you to increase the Tick Size in the opened charts as you require: Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
