Date/Time: Sat, 21 Nov 2026 07:15:10 +0000
[Programming Help] - HIGH/LOW of an indicator
View Count: 1061
| [2020-02-24 05:18:06] |
| User917679 - Posts: 76 |
In spreadsheet programming, is it possible to get the high or low of any indicator(instead of just the candle sticks/heiken-ashi etc)? If so, how do you get the high/low data? |
| [2020-02-24 12:57:40] |
| Sawtooth - Posts: 4362 |
You can use the High/Low For Time Period study, or the HightestHigh/LowestLow Over N Bars study, with the 'Based On' set to an indicator, and reference their output to spreadsheet columns. It's also possible to do this with formulas. |
| [2020-02-24 15:04:29] |
I slept on it and actually woke up w/ an idea, but I'll definitely try this first as it seems way more direct. Another question if you don't mind: is it possible to "freeze" an indicator's value at the time an order is placed, and have it stay frozen indefinitely because of the placed order? |
| [2020-02-24 16:10:06] |
You can do this by creating a persistent variable.Here are some examples: Spreadsheet Example Formulas and Usage: Persistent and Incrementing Variables |
