Date/Time: Sun, 05 May 2024 11:42:29 +0000
Automatical renewal
View Count: 508
[2020-02-23 13:58:10] |
User699988 - Posts: 8 |
Hello, how do I cancel the automatical renewal of my account? Thank you! |
[2020-02-23 23:42:38] |
There is nothing you need to do. It will not automatically renew since there is not a sufficient service balance to renew the service package and there is no automatic billing. Also we see you are running an older version. You should update to the current version following these instructions: Software Download: Fast Update Sierra Chart now offers a Delayed Exchange Data Feed: Delayed Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-23 23:44:12
