Date/Time: Tue, 07 May 2024 11:34:48 +0000
DOM P&L setting doesn't work
View Count: 770
[2020-02-23 04:58:17] |
User392279 - Posts: 67 |
format setting always show in Points. It does work at attached trading window. so they don't match. Version 2055
Date Time Of Last Edit: 2020-02-23 05:10:28
[2020-02-23 08:35:21] |
You need to change this Chart Setting: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-23 08:40:27
[2020-02-23 13:21:38] |
I can't upload Screenshot. The reason I claim it doesn't work I have set it to Tick and Currency. But it still shows Point at DOM. It shows correctly at trade window though.
[2020-02-24 21:33:28] |
If you are referring to the Profit and Loss column in the DOM, then refer to the information here for how to change the display format: Chart Trading and the Chart DOM: Chart DOM Position Profit and Loss Column Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-24 21:33:43
