Date/Time: Sun, 05 May 2024 13:21:42 +0000
ZR continuous futures contract issue
View Count: 430
[2020-02-22 13:29:02] |
User102686 - Posts: 7 |
Hi, For all other symbols, I get a continuous futures contract, but only Rough Rice (ZR) does not work. Could you tell me what I have to do to get a continuous contract? Thx |
ZR-Con. 05-20.jpg / V - Attached On 2020-02-22 13:26:54 UTC - Size: 346.43 KB - 193 views ZS-Cont. 05-20.jpg / V - Attached On 2020-02-22 13:27:04 UTC - Size: 499.97 KB - 193 views |
[2020-02-23 00:50:07] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings After that go to the chart and select Chart >> Reload and Recalculate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
