Date/Time: Mon, 25 Nov 2024 01:53:48 +0000
Missing data in SC datafeed
View Count: 1186
[2014-01-07 15:51:22] |
Peter Power - Posts: 70 |
Hello, I subscribed to SC datafeed and it seems I am missing data. It occurs on 6.1.2014 from 21:14 to 21:19 GMT time. I am using 2min timeframe and this leads to strange bar size when the markets open (14:30 GMT). Instead of having bars at 14:26, 14:28, 14:30, 14:32 etc. I see 14:27, 14:29, 14:30, 14:32. My session chart settings is as follows. Day: 14:30:00 - 21:14:59, Evening: 21:15:00 - 14:29:59. I tried also deleting and downloading the chart withouth any luck. |
[2014-01-07 16:23:59] |
What is the symbol? The reason you have odd numbers for the starting times is because this is the starting time: Evening: 21:15:00 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-07 16:24:12
[2014-01-07 16:44:17] |
Actually it is in all symbols I trade: YM, NQ, ES, EMD. I am not sure I understand what do you mean. Are you saying that it is bad because the time for starting the evening session is 21:15:00? What would be the correct day and evening session?
[2014-01-07 16:58:37] |
During 16:15 to 16:29 New York time which is equivalent to 21:15 GMT, the market is closed for those symbols. You can use whatever Session Times that you require. We recommend consulting with the exchange times in the contract specifications. If you just want the bars to start at an even time, the Evening Start Time needs to be an even number. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
