Date/Time: Sun, 05 May 2024 12:48:32 +0000
Symbol setting / P/L trade window differs from activity log
View Count: 458
[2020-02-22 12:15:30] |
User351605 - Posts: 76 |
The tick value of F.US.FVAV 5yr treasury bond is $7.8125. In the symbol settings it's displayed correctly. If I trade this symbol in SIM and close the trade with 10 ticks profit, the activity log shows me 100$ profit / 13 ticks. Is there a wrong calculation in the chart settings or is it the activity log? Even if 13 ticks would be correct, the currency value should be $101.56, and not 100. |
[2020-02-23 06:35:20] |
You need to update Sierra Chart to the current version for proper support for the value format for bonds: Software Download: Fast Update Not sure if the issue is related to this, but it would seem to be because there was a recent change to the different formatting settings for these. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
