Date/Time: Tue, 07 May 2024 14:33:45 +0000
3rd System
View Count: 568
[2020-02-22 07:47:59] |
User78442 - Posts: 260 |
I'm thinking about activating a 3rd system (5) with Denali data - What would be the additional monthly cost?
[2020-02-23 13:13:05] |
We need to discuss this and get back to you because typically the CME would want an additional ~450 USD a month extra for this. But you might just be able to do this with a second Sierra Chart account. Will be much cheaper.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-23 13:13:45
[2020-02-24 16:23:12] |
SC Support - Posts: 1797 |
Hi User78442, we can speak about this when you have time. Thank you
[2020-02-24 18:50:55] |
So you will need to set up a second Sierra Chart account to be able to use CME group data at the nonprofessional fees, on more than two systems.
[2020-02-25 05:13:27] |
OK
