Date/Time: Sun, 05 May 2024 15:05:22 +0000
Volume Composite POC On Charts
View Count: 990
[2020-02-22 03:37:54] |
DGee - Posts: 82 |
I have two charts (CL)side by side (attached pics) that was duplicated from previous charts. I have a 15 min bar and a 2 min candle chart that the volume point of control that is off quite a bit. The 15 min bar chart that has a 20 and 5 day volume profile composite point of control lines up to the tick at 53.20 The 2 min candle chart that has a daily volume profile and both 20 and 5 day composites VPOC do not match. The 20 day is at 51.34 and the 5 day is at 53.02. Can you help where I can be wrong here? Why don’t these POC all match when comparing charts? I have an ES chart that is set up the same way and both 15min Bar Chart and the 2min Candle Chart point of control all matches where they are supposed be on both charts. Any insight you can help me with? Thank you! |
Private File Private File |
[2020-02-23 00:45:03] |
Refer to: Volume By Price Study: Volume Profile Differences Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
