Date/Time: Sun, 05 May 2024 15:32:52 +0000
NYSE/NASDAQ Stock Quote - change
View Count: 696
[2020-02-22 02:49:58] |
User811622 - Posts: 38 |
I'm using Sierra Chart to see NYSE/NASDAQ stock quote. Currently the default "Price Display Format" and "Tick Size" in chart settings are set to .01 and .01, respectively. I wan to change the default to .1 and .1, respectively. So when ever I bring up stock quote, it will have .1 and .1 value, respectively. How do I make this change globally? Please see attached screenshot.
NYSE-symbol.PNG / V - Attached On 2020-02-22 02:46:48 UTC - Size: 47.34 KB - 171 views |
[2020-02-22 22:28:24] |
This is done through the Global Symbol Settings: Global Symbol Settings In the case of the symbol you show the Chart Settings screenshot for, you would want to change the settings on the ?? symbol pattern. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-22 22:28:47
