Date/Time: Sun, 05 May 2024 08:51:27 +0000
Suggestion REQUEST or work around
View Count: 778
[2020-02-21 19:41:23] |
User220914 - Posts: 239 |
MY suggestion or question is about TIME vertical GRIDLINES Under advanced settings 2 would it be possible to add a MAJOR and a MINOR vertical gridline and have them be different widths and times? esample. you could enable a minor grid line at 1 minute and a major grid line at 30 minutes etc. i fyou already have a way of doing this could you point me inthe right direction. thank you |
[2020-02-22 03:53:42] |
Merlin - Posts: 81 |
I've had this exact feature on my charts for several years, I find it very useful. I didn't remember how I did it, so I had to go back and look! Turns out I wrote a simple ACSIL study for the Major gridlines. (I think I wrote it myself, but maybe I found it somewhere?? If someone else wrote it, I apologize in advance - I honestly don't remember!) Here's the code, you'll need to compile it. Enjoy! P.S. for Sierra: I agree with the user that this would be a worthwhile native feature. |
Merlin N-Minute Gridlines.cpp - Attached On 2020-02-22 03:50:44 UTC - Size: 2.34 KB - 205 views |
[2020-02-23 02:40:46] |
This is not supported for Vertical grid lines, therefore this is a feature request. Just so you are aware, this feature is already in place for Horizontal grid lines. Refer to the information here: Chart Scale and Scale Adjusting: Horizontal Grid Line Increment (Scale Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
