Date/Time: Sun, 20 Sep 2026 14:07:29 +0000
ASCIL Hide Main Line Keep All Others
View Count: 1051
[2020-02-21 16:10:32]
User439067 - Posts: 48
trend_lines.ChartNumber = sc.ChartNumber;
  trend_lines.DrawingType = DRAWING_FAN_FIBONACCI;
  trend_lines.EndDateTime = sc.BaseDateTimeIn[sc.Index];
  trend_lines.ShowLabelsAtEnd = 0;
  trend_lines.ShowAngle = 1;
  trend_lines.Color = COLOR_BLUE;
  trend_lines.RetracementLevels[0] = -100.0f;
  trend_lines.LevelColor[0] = COLOR_DIMGRAY;
  trend_lines.LevelStyle[0] = LINESTYLE_DOT;
  trend_lines.LevelWidth[0] = 1;
My example is above. I want to hide the 'main' line (BLUE) but keep all the retracement lines. How can I do this?
[2020-03-04 19:16:34]
Anybody have an answer? I have a mostly useless line in my study that I want to hide but I can't figure out how. The line specifically between the two points of the DRAWING_FAN_FIBONACCI that I want to hide. I just want to see the retracement levels.
[2020-03-04 19:39:42]
Refer to the last sentence in this section:
Using Drawing Tools From an Advanced Custom Study: s_UseTool::RetracementLevels[]
[2020-03-04 20:58:19]
Using a value of FLT_MAX at a particular index in the RetracementLevels[] array means that level will not be drawn.
For those interested. Here is the 'particular index' I used and it seemed to do the trick. /shrug
tool.BeginDateTime = sc.BaseDateTimeIn[FLT_MAX];
[2020-03-04 21:40:09]
User183724 - Posts: 194
can you set the line color as same as chart background color. black line on black screen would make it invisible but still have it there for reference by formulas
[2020-03-04 21:41:54]
I did try that but anytime it went through a candle it would show up. Thanks!
