Date/Time: Mon, 25 Nov 2024 03:05:22 +0000
CandleStick Patterns Finder for ascending/descending triangle
View Count: 1506
[2014-01-07 15:35:29] |
moonmist - Posts: 127 |
Hi, Can the Candlestick Patterns Finder study identify ascending and descending triangles ? Thanks. |
[2014-01-08 11:54:20] |
Hi, I presume the answer is no. In this case, I'll code my own finder. PS: I posted the above question just to make sure that I am not going to re-invent the wheel. Date Time Of Last Edit: 2014-01-08 12:21:29
[2014-01-08 17:45:39] |
No, it cannot do this.
