Date/Time: Wed, 01 May 2024 20:08:25 +0000
[Programming Help] - View Cumulative Last Size at Bid/Ask and Cumulative Last Size at Price Concurrently in DOM
View Count: 1064
[2020-02-21 14:59:07] |
User120942 - Posts: 71 |
@Sierra Chart Engineering, Currently, the cumulative last size column can be reset based on Bid Ask Change or reset based on price change via the Reset Cumulative Last Size on Bid Ask Change setting in (Global Settings >> Chart DOM Settings), which is great. But this setting does not give me the option to display both values in the DOM at the same time in Sierra Chart. Global Trade Settings Windows: Reset Cumulative Last Size on Bid Ask Change (Global Settings >> Chart DOM Settings >> Other >> Other Settings) I would like to have the option to see both values at the same time so that I can view the cumulative last size at bid/ask compared to cumulative last size at price side by side. This would be helpful as a snapshot of the values in the Sierra Chart Time and Sales window as shown in the attached examples. To achieve this result I am requesting one of the following options be implemented: 1. A setting to see both values (Cumulative Last Size at Bid/Ask and Cumulative Last Size at Price) concurrently in the cumulative last size column. or 2. Two separate DOM columns for each cumulative last size value i.e. (a Cumulative Last Size at Bid/Ask column and a separate Cumulative Last Size at Price column). I have attached screenshots of how this currently appears in Bookmap to illustrate. Thank you for your consideration. |
Sierra Chart Combined Cumulative Last Size.png / V - Attached On 2020-02-21 14:24:26 UTC - Size: 438.69 KB - 390 views Combined Cumulative Last Size.png / V - Attached On 2020-02-21 14:24:32 UTC - Size: 987.79 KB - 254 views Reset Cumulative Last Size on Bid Ask Change.png / V - Attached On 2020-02-21 14:26:16 UTC - Size: 21.43 KB - 273 views |
