Date/Time: Tue, 07 May 2024 13:59:22 +0000
Numbers Bars Study: Nonzero Bid&Ask at High/Low Extension Lines randomly reset.
View Count: 431
[2020-02-21 12:40:59] |
User161648 - Posts: 3 |
Dear SC, I encountered a strange occurrence with the numbers bars study while the High(Blue)/Low(Pink) value randomly reset I have attached the pictures for your reference. Issue1_01: The bar which I highlighted, Blue is 27312 and Pink is 27300 which are correct and I also found the same in the Spreadsheet Issue1_02: Few bars later, the Blue value reset to 0 .... and I noticed that the Blue value remain the same in the Spreadsheet also. Could you please advise? Thx. |
Attachment Deleted. Private File Private File |
[2020-02-25 09:12:31] |
Extension line Subgraphs should not contain any data and we would expect them to always be zero. Not sure why they would have a value. In any case you should certainly not be relying on them to be anything but zero.
