Date/Time: Mon, 25 Nov 2024 02:51:21 +0000
Count down timer
View Count: 1273
[2014-01-07 15:15:59] |
User26059 - Posts: 19 |
Any ideas why the count down timer does not function in real time on a 30 market profile chart? It just shows zero. Thanks |
[2014-01-07 19:09:31] |
It may not work properly on a TPO Profile Chart. Most studies do not work properly on TPO Profile Charts. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html#UsingOtherStudies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
