Date/Time: Tue, 04 Nov 2025 18:18:15 +0000
[User Discussion] - Using constant range scale when switching between symbols
View Count: 2537
[2013-04-14 02:37:50]
M5amhan - Posts: 468
Hello
I had a problem for a while with a study I made that I finally have figured out a solution for. It wouldnt stay in the same place on the charts (it would move around with the price, I think I made a post about this here), anyway the solution was to use constant range for the entire chart. But now when I switch between symbols there is a huge difference and I have to fix each chart (5 of them) every time a new symbol is clicked.
I guess Im asking if this could be revised for those of us using one chartbook (with constant range) and a quoteboard. Im sure it would be an easy fix, maybe using number of ticks instead of the actual price. I dont know, Im not a programmer. Just so the bars can be readable after switching to a new symbol.
imageCL.PNG / V - Attached On 2013-04-14 02:33:30 UTC - Size: 53.72 KB - 917 views
[2013-04-14 18:20:58]
This was not meant for user discussion
I am asking if this could be fixed for a future release.
[2013-04-14 18:27:25]
I dont believe I am pointing out something that is irrelevant this time, if you could just look into it please
Date Time Of Last Edit: 2013-04-14 18:27:52
