Date/Time: Wed, 05 Feb 2025 00:58:58 +0000
Percent Change since open
View Count: 618
[2020-02-21 08:59:28]
User551971 - Posts: 34
Hi, I have built two charts with which I would like to see the changes in percent. Picture in the attachment. On the left side everything is ok on the right side is not. On the left I let it in the Chart Region 2 indicate what also works right in Chart Region 1. Why does it not work in Chart Region 1 or must one there still something adjust?
thx
imageChange_Percent.png / V - Attached On 2020-02-21 08:58:59 UTC - Size: 52.3 KB - 241 views
[2020-02-21 09:06:19]
Ackin - Posts: 1865
This can be anything ... I doubt that without a broad description or the attached chartbooks you will get any answer.
Use the duplicate chart feature. This will avoid missing adjustments in the second graph.
Select Chart >> Duplicate Chart on the menu.
Date Time Of Last Edit: 2020-02-21 09:13:50
[2020-02-21 09:19:52]
I have already duplicated the chart. But always the same error.
Here my Chartbook
Thx
attachmentChange_Percent.Cht - Attached On 2020-02-21 09:18:14 UTC - Size: 61.36 KB - 326 views
[2020-02-21 11:56:56]
Ackin - Posts: 1865
The study has a percentage result / Your graph has a points + OHLC visible bars (source of possible problems, different scales)
try set in the settings of study:
Settings and Inputs Tab >> Display As Main Price Graph
or
move the study to the chart region2 (in the study settings)
[2020-02-24 17:09:03]
That's it. Now all is fine
Thank you
